delta448
DSM Wiseman
- 3,626
- 315
- Jan 13, 2006
Waynesburg,
Pennsylvania
Well, it's not technically the same for either, but it's the best compromise between optimizing each of the two since they're generally opposites.How exactly does this setup do that? I'm just trying to understand how/why this works so well.
Dennis already noted the biggest points, so I'll just add a little:
More lever arm length (crank throw) with the same amount of force (combustion pressure) applied to the end (rod journal) generates more torque. Same holds true when you use a cheater pipe on a wrench. I'm sure you don't need me to elaborate even this much. It's the basic principle of why increasing stroke on any engine is so beneficial.
The 94mm crank splits the middle between the 100mm (2.4) and 88mm (2.0) perfectly. When you couple that with the 2.4 block made to accommodate a 100mm crank, you use longer rods and end up with a rod ratio that is nearly the same as a 2.0 4G63.
You can use up to or slightly more than a 159mm length rod with a 94mm crank and custom wrist pin location piston. A rod length of 159mm with a 94mm crank would give a rod ratio of 1.69. Chris's 156mm rod gives him a ratio of 1.66. For comparison, a stock 4G63 with a 150mm rod has a 1.70 rod ratio and a 2.3 stroker has a rod ratio of 1.5.
Using longer rods with higher ratios does a couple things:
- Transfers less force into side loading which equals:
- less friction,
- less heat,
- less egging of the cylinder bores,
- less stress on the piston's wrist pin.
- Increases the TDC and BDC dwell time of the piston, which can:
- increase Mass Fraction Burned,
- lower pumping losses from high ignition advance angles,
- is more forgiving of incorrect ignition advance
- reduces stresses on the con rod and it's cap bolts in tension at TDC on the exhaust stroke
