Compairing a 2.3L to a 2.4L
Scott_S
182
4
Feb 17, 2006
Austin, Minnesota
My motor just crankwalked so I'm going to start gathering things to build a new one. Basically I'm thinking of two different routes and I would like some opnions on them. The first thing I was thinking about was a 6 bolt 2.3 stroker swap with the SBR stage 3 kit. Pretty straight foward there but I would need basically a complete 6 bolt and the kit on top of it. I was at LSE today and I was talking to the guys there and they suggested going for a 2.4 in that case I would need a 64 block and a 1g head and I dont know how much more complicated the swap is but I'm sure there are wirte ups all over. Is there a big selection for bottom end parts for the 64? Basically for the 6 bolt bottom end I'm looking at spending around $1700 for the short block and idea how much a 2.4L would be with similar ratings?(hold up to 800hp). And do the advantages of the extra .1L of displacement out weigh the hassel of the swap or is it smarter to just go 2.3?
Scott_S said:
I was at LSE today and I was talking to the guys there and they suggested going for a 2.4....
Just curious, what was LSE's reasoning behind recommending a 2.4 versus a 2.3?
I guess they believe the more displacement you can have the better. One person told me that in all actuallity a 2.3 is actually a 2.35L and a 4g64 also is a 2.35L so its basically the same thing
A "2.3" is a 4g63 with stock 85mm bore x 100mm stroke = 2.270L
A "2.4" is a 4g64 with stock 86.5mm bore x 100mm stroke = 2.351L
A 4g63 bored 60 over is 86.5mm bore x 100mm stroke = 2.351L
and so on...
I didnt relize there was enough metal to go .090 over....
Ummm... what non-euclidean geometry do you live in?? 88mm bore with 100mm stroke will only give you 2.43L.
hakcenter said:
i think the only differences between a 2.3 and the long rod 2.4 is possibly the pistons. The deck on the 2.4 is taller, so your going to have to use the 2.4 timing belt.
But if you got the cash, I think a 2.4 would definatly be a better choice over the stroked 2.0.
The long rod 2.4L uses 156mm rods instead of the standard 150mm rods.
wishihadatalon said:
why would you say that? I know someone who received the wrong pistons and decided to have the block bored 90 over. The motor had super low compression and love the 500+ whp it saw everyday.
There's not enough material between cylinders to bore it 90 over. I've *never* seen an experienced machine shop that would go more than .030 -- most won't even do that.
There's enough material for more than 30 over. A 4g64 is supposedly the same casting, just a taller deck height, and with its 86.5mm bore it's already "60 over" from the 4g63. It's common to go to 87mm which is "80 over" from a 4g63. I wouldn't do it, but it's been done.
Hakcenter, a LONG ROD 2.4 is not a normal 4g64. It uses a 156mm rod instead of a 150mm (which both 4g63 and 4g64 use), and uses a stroker style piston with a 6mm raised wrist pin to fit in the same deck height. This helps the rod/stroke ratio somewhat (1.56 instead of 1.5).
hakcenter said:
Maybe you can help me find some 156mm rods then, cause I have not been able to locate any.
I know Manley makes 162mm rods, for a de-stroked 4g64 w/ 4g63 crank, but still can't locate any 156mm rods.
http://www.magnusmotorsports.com/engines/dsm.htm
Correct, the 4g63 and 4g64/g4cs all have the same rod length. The 4g64/g4cs comes with the the same rods found in 6 bolt 4g63's (the "big" rods).
Why wouldn't you get a 2.3 stroker that can rev highter then. Do you even know what the rest of your setup is going to be? Turbo selection and many other things play a role in what you should get. I knew the LSE guys before they even had teh shop opened and I am fairly certain their shop 1g is going to be running a 2.0 actually. I think they were trying to go for shep also but that would be hard to do. The car won't be running until next season most likely though.
The motor I will be running soon is a 2.3 stroker bored .030 over with 9:1 pistons.
BTW, there is a local dsm site www.dsmstyle.com if you don't know yet.
My goals are this. The car will be a daily driver. I want more low end because of this and the fact that On a normal basis I never go above 7200rpm. The car is also an ongoing project and I want to eventually be running 500-600awhp but that is far off into the future and I'm going to take things one at a time. For a turbo I'm looking at the garrett gt series and I've still iffy about what I actually want to run. I plan on running 1000cc injectors with link obviously, comp 101200 cams, ported head, SMIM, and all the other little mods(fuel pump, AFPR, ect) But like I said I'm not talking about doing it all at once because I can't afford it, heck I can't even afford to build the bottom end.
Pauter, Oliver, Manley and Groden all offer 156mm rods. You just have to call. There really isn't much point to it though. The whole reason Magnus did that was so they could have a lighter piston, that much of a change in rod ratio isn't going to help enough to notice.
The main reasons most shops recommend the 2.3 over the 2.4 is because of strength. and cost The 2.3 block is semi-girdled, opposed to the 4g64/G4CS block which is not. The 2.4 blocks/cranks are a little harder to come by. You can make a ton of power on either, but the main bearings will take more abuse in the 2.4 block.
Good idea with going with a GT series, the GT35Rs are a good match up to the 2.3L, stroker. SBR has a stage 2 stroker kit, that can take 800hp for 1499$ its for the 6-bolt engine. I have talked with Andy(Andymoraitis) and he has the 200s, but he said if he were to do it over again he would go with the FP3 cams, they are specificly made to maximize the efficiency of the 2.3L stroker.if your going with a Gt your going to need more then an SMIC, the SMIC will fall short of your 600hp mark.
Good luck, and keep us up-dated
Dustin
SMIM not SMIC. I already have a front mount. Unfortinatully due to the costs of school I have dicided to sell the talon. I'm kind of looking at an srt-4 currently
Oh sorry for the missunderstanding. Why spend all that cash on an srt-4, if your straped for money, fix the 7-bolt if its a cheap fix, and have the main caps machined specificly for your crank, and violia no more possibility of CW, just as stout as a seasoned 6-bolt. http://www.angelfire.com/pa4/crankwalk/
Dustin
Dustin
Machining the main caps isn't a guaranteed solution. The only 7 bolts that are more resistant to CW have the revised split thrust washer design found in the late 98 and all 99 blocks. Even those aren't guaranteed, but they work much better than the flanged bearing design on the earlier 7 bolts. Anything wih a piston can walk. Anything.
Huh, learn a new thing everyday. Yeah I know anything with a piston can walk, but 7bolts...well earlier then 98/99 engines are more prone in our DSM land do to the lazyness of mitsu with the main caps for the cranks.
Dustin
