2.3 stroker build. Rod hits block!????? (PICS)
DeadlyAKrunna47
169
31
Jul 9, 2009
Seattle, Washington
OK im building a 2.3 stroker 6bolt using wiseso stroker pistons, eagle H rods, and oem 100mm crank. I put number 2 and 3 rod/piston in the block and number 3 is hitting the block??? I have never heard of this?:confused:
I could die grind it out, but i hope there is no oil passage right there.
What do you guys think? has this happend to anyone else?
<a href="http://s39.photobucket.com/albums/e173/willywonders00/?action=view&amp;current=P1140611.jpg" target="_blank"><img src="http://i39.photobucket.com/albums/e173/willywonders00/P1140611.jpg" border="0" alt="Photobucket"></a>
<a href="http://s39.photobucket.com/albums/e173/willywonders00/?action=view&amp;current=P1140612.jpg" target="_blank"><img src="http://i39.photobucket.com/albums/e173/willywonders00/P1140612.jpg" border="0" alt="Photobucket"></a>
<a href="http://s39.photobucket.com/albums/e173/willywonders00/?action=view&amp;current=P1140613.jpg" target="_blank"><img src="http://i39.photobucket.com/albums/e173/willywonders00/P1140613.jpg" border="0" alt="Photobucket"></a>
Grind it.. Very common on 6 bolt strokers. I actually use a file to make the clearance.
