1st logs. Knock count of 43
gotitjr
31
Jan 15, 2008
Evanston, Wyoming
I'm sorry they are hard to read, i am new to all of this. From 4400rpm up has very bad knock. Can someone please help me fix this?
Code:
TIMA
 O2-R
 TPS
 ACLE
 KNCK
 INJP
 AIRT
34.00º
 0.02V
 226.44Hz
 3093.75rpm
 2.52V
34.00º
 0.02V
 239.02Hz
 3093.75rpm
 2.52V
34.00º
 0.02V
 226.44Hz
 3187.50rpm
 2.52V
34.00º
 0.02V
 352.24Hz
 3156.25rpm
 2.52V
31.00º
 0.02V
 389.98Hz
 3187.50rpm
 2.52V
30.00º
 0.02V
 421.43Hz
 3125.00rpm
 2.52V
29.00º
 0.02V
 459.17Hz
 3218.75rpm
 2.52V
27.00º
 0.02V
 515.78Hz
 3281.25rpm
 2.52V
26.00º
 0.02V
 610.13Hz
 3281.25rpm
 2.52V
25.00º
 0.02V
 654.16Hz
 3406.25rpm
 3
 2.52V
24.00º
 0.02V
 729.64Hz
 3468.75rpm
 3
 2.52V
21.00º
 0.02V
 805.12Hz
 3500.00rpm
 3
 2.52V
20.00º
 0.02V
 836.57Hz
 3687.50rpm
 2.52V
20.00º
 0.02V
 855.44Hz
 3687.50rpm
 2.52V
21.00º
 0.02V
 912.05Hz
 3843.75rpm
 2.52V
20.00º
 0.02V
 905.76Hz
 3875.00rpm
 2.52V
21.00º
 0.02V
 918.34Hz
 4000.00rpm
 2.52V
21.00º
 0.02V
 937.21Hz
 4000.00rpm
 2.52V
22.00º
 0.02V
 974.95Hz
 4125.00rpm
 2.52V
22.00º
 0.02V
 1018.98Hz
 4218.75rpm
 2.52V
22.00º
 0.02V
 1063.01Hz
 4187.50rpm
 2.52V
21.00º
 0.02V
 1081.88Hz
 4218.75rpm
 2.52V
21.00º
 0.02V
 1157.36Hz
 4500.00rpm
 2.52V
21.00º
 0.02V
 1220.26Hz
 4406.25rpm
 19
 2.52V
14.00º
 0.02V
 1201.39Hz
 4750.00rpm
 18
 2.52V
14.00º
 0.02V
 1327.19Hz
 4843.75rpm
 18
 2.52V
14.00º
 0.02V
 1358.64Hz
 4968.75rpm
 18
 2.52V
12.00º
 0.02V
 1547.34Hz
 4718.75rpm
 23
 2.52V
10.00º
 0.02V
 1591.37Hz
 5187.50rpm
 23
 2.52V
10.00º
 0.02V
 1603.95Hz
 5218.75rpm
 23
 2.52V
9.00º
 0.02V
 1603.95Hz
 5125.00rpm
 22
 2.52V
10.00º
 0.02V
 1603.95Hz
 5187.50rpm
 25
 2.52V
9.00º
 0.02V
 1603.95Hz
 5406.25rpm
 25
 2.52V
10.00º
 0.02V
 1603.95Hz
 5468.75rpm
 31
 2.52V
8.00º
 0.02V
 1603.95Hz
 5343.75rpm
 31
 2.52V
9.00º
 0.02V
 1603.95Hz
 5468.75rpm
 31
 2.52V
9.00º
 0.02V
 1603.95Hz
 5500.00rpm
 31
 2.52V
10.00º
 0.02V
 1603.95Hz
 5687.50rpm
 30
 2.52V
10.00º
 0.02V
 1603.95Hz
 5750.00rpm
 31
 2.52V
10.00º
 0.02V
 1603.95Hz
 5812.50rpm
 31
 2.52V
11.00º
 0.02V
 1603.95Hz
 6062.50rpm
 30
 2.52V
11.00º
 0.02V
 1603.95Hz
 6062.50rpm
 37
 2.52V
9.00º
 0.02V
 1603.95Hz
 6031.25rpm
 37
 2.52V
8.00º
 0.02V
 1603.95Hz
 6000.00rpm
 37
 2.52V
8.00º
 0.02V
 1603.95Hz
 6000.00rpm
 36
 2.52V
8.00º
 0.02V
 1603.95Hz
 6406.25rpm
 43
 2.52V
6.00º
 0.02V
 1603.95Hz
 6375.00rpm
 43
 2.52V
5.00º
 0.02V
 1603.95Hz
 6343.75rpm
 43
 2.52V
5.00º
 0.02V
 1603.95Hz
 6343.75rpm
 42
 2.52V
4.00º
 0.02V
 1603.95Hz
 6375.00rpm
 42
 2.52V
5.00º
 0.02V
 1603.95Hz
 6437.50rpm
 43
 2.52V
5.00º
 0.02V
 1603.95Hz
 6593.75rpm
 42
 2.52V
4.00º
 0.02V
 1603.95Hz
 6468.75rpm
 42
 2.52V
5.00º
 0.02V
 1603.95Hz
 6531.25rpm
 43
 2.52V
4.00º
 0.02V
 1603.95Hz
 6625.00rpm
 43
 2.52V
3.00º
 0.02V
 1603.95Hz
 6656.25rpm
 42
 2.52V
4.00º
 0.02V
 1603.95Hz
 6656.25rpm
 42
 2.52V
4.00º
 0.02V
 1603.95Hz
 6750.00rpm
 42
 2.52V
4.00º
 0.02V
 1308.32Hz
 6562.50rpm
 41
 2.52V
It looks like the timing belt skipped a few teeth. If you're going to get a built engine, I would choose Buschur over SBR and Engintecs over both of them.
Home
Depending on your goals you might not need a forged bottom end, I would give Mitch a call and discuss your options.
Do you guys think I bent the valves? Is there anyway to tell without taking everything apart, or taking it to a shop, I cant get it looked at by a professional because there are no shops here that can do it, I would have to send it off. If it is warped i have no choice though.
I would be shocked if you did not bend some valves. The quick & dirty check is with the sparkplug in valves closed set the head chamber up and fill it with water. If it runs out eather port you have bent valves.:cry:
Honestly, judging by the way the car was knocking and such, i think that
someone else before you broke the t-belt, bending the valves and causing the piston
tovalve contact. I think your excessive knock has caused the hg to blow between the 2 cylinders. Remember, knocking is the flame front of the compression stroke being
compressed at the wrong time. This would cause your headgasket to blow between 2
cylinders, and make your car run crappy (compression sharing between 2 cylinders will
cause knocking as well, because when the one cylinder gets fired off, instead of the
compression staying in the cylinder and the momentum moving the piston down, it seeps into the next cylinder and fills it with unburnt fuel/air.) I honestly think the piston
to valve contact happened BEFORE you got the car. How far are you from SLC, UT??
Those marks could be from a previous valve/piston encounter. I have torn apart several engines to find valve marks in the pistons from a previous head. That could be also the reason for part of your knock problems as there are some good hot spots probably from the dented areas. You can usually tell if your valves are bent when you turn the cams over you can clearly see if they seat properly or not.
    • Sdcryan1
