1g wires - tranny, knock sensor?
erecker
Jul 10, 2004
Indiana
The (awd)MT transmission has a two wire plug on the top, I believe it is either a reverse or neutral switch. The car's been in too many pieces for too long, and I can no longer identify which wire from the harness is supposed to plug in here. Would someone enlighten me on what the wire colors are to be hooked up here??
Also, the knock sensor has two plugs it will will fit into on the harness. Colors?
Is there a map somewhere with wire colors for identified harness components? I searched and found nothing solid.
Thanks in advance!
~Eric
I remember having a reverse light switch on top of the trans when I had a 1g cause I remember breaking it off when I took the trans out. Not sure what wire colors they were but if you go to autozone.com and put in your vehicle info and push Repair Info --> Vehicle Repair Guides --> Chassis Electrical --> Wiring Diagrams. I tried looking real fast but I'm sure you can figure it out faster then me.
