1G Knock sensor bad?
Colinssweeney
11
Dec 30, 2021
Calgary, AB, Canada
Just got my talon running, and was doing some logging. My ECMLink was throwing a “Knock sensor circuit” code. Turns out the wiring was messed up, but I fixed it and that cleared the code.
Here is what has me confused. I’m not throwing codes anymore, but my log shows 0% KnockRet for the entire test drive (which seems wrong to me).
I assume it would throw a code if the knock sensor was faulty…
Any ideas?
My logs almost always show 0 knock. That’s what you want. It’s a good thing
Yeah I just didn’t think it was likely, but hopefully that’s the case.
Check the sensor, or the ecu has a issue.
Not the ecu, because before I rebuilt the head the knock detection worked fine and showed in my logs. If the sensor was faulty wouldn’t it throw a code?
When do you typically see knock? I’m still on break in for rod bearings, so I haven’t gone above 50% throttle and waste-gate pressure of 5psi.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
