1g Whining turbo
shoota143
Jul 9, 2004
Cherry Valley, Illinois
when the turbo kicks in on my 1g it has a whining sound to it..please dont tell me its byebye
Its possible the turbo is on it's way out. Are you blowing smoke during boost, if so make sure you check oil level daily.
the higher the boost the louder the whinning will be. i think it might be the bearings going out in it...it does blow a little smoke, which i am worried about, i was thinking if it was the bearings there would be some oil in the lines but there is no sign of oil. i was thinking the smoke could be the bad value seals i have, w/ bad seals the smoke usually clears up as it does.
