1G 1G VSS
ItsTwan309
Supporting Member
233
252
Apr 20, 2020
Pekin, Illinois
I was had the dash out requiring some gauges the other day.
I put it all back together and now ECMLink is not getting a signal for vehicle speed.
The dash gauge works though. I didn’t notice this until after cruising the car and it running very poorly.
Any tips on how to get this function back?
On a 1G the VSS is a magnetic reed switch inside the speedometer that makes and breaks a connection to ground. The ECU provides a pull-up to +5v and senses the pulses caused by the switch connecting to ground as the speedometer cable moves. The cruise control and TCU, if present, also do the same.
It's not unknown for the reed switch to die and if it does you can either replace the gauge or the switch inside.
Just the man I hoped would answer!
Ok, I’ll peel it open and see if it’s shot, I have a spare cluster I could try as well so maybe that first
  • For sale 1g MD122260
    Up for sale Discontinued MD122260 Forward Facing Oil Filter Housing $120.00 shipped plus paypal...
  • For sale 1999 Mitsubishi Eclipse GSX 5 Speed
    Selling a 1999 Mitsubishi Eclipse GSX. 5 speed manual, Red on Tan leather. 83,500 miles.
    • radron26
  • For sale 1g Carbon fiber center tail section
    Carbon fiber cover for center tail light light section
    • arodgst
