Anfurnyy
Supporting Member
- 1,515
- 1,970
- Jul 4, 2020
Rapid City,
South Dakota
Got an issue I've been chasing for a few months now. My speed sensor on the transmission is leaking.
I've got a Brantz speed sensor adapter for my link g4+ ECU. Should be irrelevant?
I've already replaced the o-ring with a non-oem but it was the same size and it still leaks. It looks like it's leaking from inside the speed sensor itself as the speedo rod is also covered in oil. Not sure if there's more seals inside the sleeve that's seal off the actual rod/ gear but I can't get mine disassembled to find out.
I have a new OEM o-ring and new sleeve coming from STM but also looking for any advice / if someone has one they wanna let go. I'll make a post in classifieds as well
