1g vs 2g viscous coupler
AlphaVision
297
Jan 28, 2007
Sofia, Europe
Hello, guys. I am doing a transmission rebuild and I have a 1g tranny for parts to go into a 2g tranny. I noticed that the viscous coupler is smaller in the 1g tranny so can you please tell me which one is better and can I use the 1g VC into the 2g tranny
After digging dome more here is what I found out.
The transmission with the small VC is from a non turbo AWD 1g. Those are very rare models produced for snowy countries like Sweden, Finland (maybe Canada as well). It is the same as 1g Turbo AWD except for:
1. front differential
2. center differential
3. viscous coupler
4. 1st speed
5. input shaft
I gues 2 is connected to 3 and 4 is connected to 5.
So i need info on this tranny especially on the center and front dif ratios. Also - can anyone tell me what is the drivetrain balance between front and rear wheels on a 2g AWD car? Is it 50:50?
Here are the specs of both transmissions I have. I am taking the first gear from the NA tranny and if the center diff along with the VC are better :)
Code:
|   Gears    |1G NT AWD MT (EURO)|  2G AWD MT  |
|	     |	  W5M33-2-WPBV   |W5M33-2-MUZT |
|     1      |	      2.846	 |    3.083    |
|     2      |	      1.684	 |    1.684    |
|     3      |	      1.115	 |    1.115    |
|     4      |	      0.833	 |    0.833    |
|     5      |	      0.666	 |    0.666    |
|     R      |	      3.166	 |    3.166    |
|  Primary   |          X        |    1.275    |
| Secondary  |          X        |    3.800    |
|  Transfer  |        1.090	 |    1.074    |
|   Final    |        5.443	 |    4.929    |
| Rear Diff  |        3.909	 |    3.545    |
| 1 | 2.846 | 3.083 |
| 2 | 1.684 | 1.684 |
| 3 | 1.115 | 1.115 |
| 4 | 0.833 | 0.833 |
| 5 | 0.666 | 0.666 |
| R | 3.166 | 3.166 |
| Primary | X = 1.275 | 1.275 |
l Secondary | X = 4.260 | 3.800 |
1st collum has 5x vr4 gears, but Evo 1,2,3 Primary, Secondary & Rear Diff
It might be what is in the AMG VR4 NA AWD. AMG has 260/264 cams btw
2st collum is a std 2g awd mt
Cheers !
Thank you for that info. Just to make it clear - are those numbers the ones of the transmission that I have or from a VR4 tranny which seems to be the closest to mine?
By checking a list of gearing I have, it showed up as 5x vr4 gears.
You gave me the final drive of the 1st collum as 5.443
Primary x Secondary = Final drive.
So they are 1.275 - 37/29 & 4.260 - 64/15
Strange thing is the primary & secondary are from Evo 1,2,3 boxes
Cheers !
Well I got the numbers from here: http://bojo.hopto.org/Auto/Japan/Mi...1_F5M21_F5M22_F5M31_F5M33_W5M32_W5M33/22A.pdf (page 20).
Thanks for the info, mate.
Today I checked the VC and the bigger one is stiffer. I used a leverage in the center's diff holes and a useless output shaft which was locked. Then I put the VC and put some weight on the lever. The smaller VC let the weight go down faster so I gues I am changing the center diff cases and will use the bigger (turbo) one.
