viscous coupler welding?
swifteagle
317
8
Jan 18, 2012
livingston, Texas
Anyone know if you can just weld the up the back of the viscous to make a vce for dyno use? Or do you have to turn it down and then weld it.
It was worth about .2 in the 60' for me when I was trapping 124ish getting a best of 1.65 with an average of 1.70, from a 1.80 before, and a 1.85 average. Now at 133 i can't get it below 1.75.
I have my car at school right now as my only car, it hurts drive-ability, but it's not the end of the world. Just gotta be careful in parking lots and such.
I run a VCE on a 2 spider, but going back to a non locked 4 spider when I get qtp's
Band aid?? If welding it give you a 50 50 distribution of power to the front and rear? Why is that a band aid?
I dont need to be fwd for anything magnus's dyno is awd. I wanted to do this only for better 60'
Band-aiding a suspension problem by trying to add more traction through a welded viscous coupling. Fix the source of the problem. Set up your suspension correctly for a better 60'. If you can't get into the high 1.7's on street tires there's a few things you need to take a look at (suspension, driver mod, etc.)
What about with a 4 spyder center? Is there any problem using a VCE and driving around on a 4 spyder instead of welded?
Jist would like a little bit of info, the car will be mainly a track only car but it will have some street duty also. Binding up and wheel hop/drag sounds like shit. Maybe i will avoid this.
Welded diff/no power steering I feel go hand in hand.
Broke the diff at the track one time, left the line and my car did a burn out with the front tires? I was like wtf? Looked underneath blew a hole in the trans casing from the fragments. Drove it 1 hour home with no fluid. Thought for sure it was done, when I opened the trans up. Carefully inspected everything, every tiny crumb of steel from the shattered spider gear removed from all moving parts. Had center and casing welded, all bearings and other parts were surprisingly not harmed or worn!? Trans still runs and shifts like butter today.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
