1g TB on a 2g...
Tallen
20+ Year Contributor
2,739
7
May 28, 2002
Ashburn, Virginia
what does this conversion involve? i am looking into candelas TB.
I have just done it. It doesn't involve a whole lot. the hardest part is calibrating your TPS.
I should bolt up, but you'll either have to port match your 2g head or swap for a 1g to be able to use it appropriately, the runners are much larger. The more I think about how much work this is going to be, the more I want to put it off :)
Originally posted by GRNDSM
Guys, it is 91-94 that will work and if anyone is looking for one, I have it for $100
Leon
RR
i might just take you up on that - i've got a pretty much stock setup right now (aem cai is all that might make a diff but i doubt it) - what would i need to do in order to put one in? and how much you want for shipping to 33064?
so how did you go about calibrating the TPS? i tried following RRE's instructions, but the car ended up running like crap. so i rotated it until pins 2 and 4 put out .49 volts and it runs fine (i guess)
Originally posted by talonted_one
I have a 1G throttle body and a 1G intake manifold.... both went on with no complaints. I followed RRE info on calibrating the TPS and had not one problem.
If you dont mind me asking, how much work was installing the tb & mani it and what were your results?
getting the intake manifold on/off with the head on the car is near impossible.. it can be done but its a major pita..
