2G 1g swap in 2g
Ok guys I been doing research and nothing has help so far. So I fix the oil leak but now the car won’t turn over. It cranks but that’s it. I replace the coils,wires, spark plugs and fuel injectors seals and still cranks with a no start. Any ideas on what the issue can be
I’m getting fuel to the rail and cylinder. Pulled my spark plugs and they smelled like fuel so I don’t think I’m getting spark
Crank sensor been replace but not the cam sensor
More information please (smacking my head with my hand)
These motors can be made to work with various types of cam and crank sensors.
What is your CAM sensor? Is it a 1G green top, 1G black top, 2Ga or 2Gb sensor?
What is your Crank sensor? Is it a 2G sensor? Is it a Kiggly sensor on a 6 Bolt with a custom trigger plate? or are you using the crank signal from a 1G CAM sensor?
Where did you get the replacement sensor? is it made in Japan or is it a Chinese copy?
It’s a black top cam sensor and the crank is 2g sensor
Very good. The Blacktop CAM sensor can also supply a crank signal if you find out that the 2G crank sensor is dead.
How did you wire the Blacktop? There are 4 wires, Power ground and two signals. What of these 4 wires did you connect to the 3 wires in the 97 engine harness?
What kind of ECU do you have? 95 - or - 97+
It ran fine before I fix the leak. I’m getting every but a spark . Replace everything for the ignition side. Getting fuel and air still no spark
If it ran fine before you fixed the coolant leak, I'd be looking at all your wiring and connectors for ignition and make sure something didnt work itself loose or finally give up.
It’s an electrical issue not a coolant issue . Haven’t pinned point the exact cause yet
Anyone can wire harness every do this ?
It does it whenever it the cas wire harness is touch . Why I’m asking if anyone had trouble from the cas harness
