1G 1g Rear Poly Roll Stop for Automatics
So in my quest for a poly rear roll stop insert (mine is TOAST), I ordered up a Prothane #13-506 rear bushing. The ad I looked at didn’t say ‘Manual Transmission Only” on the Vendors website, so I thought Woo Hoo! Well, as we all find out, that insert is too small. The OD should be 3 1/16” for the bushing but this was slightly smaller. I called Prothane to inquire about a universal bushing and No Bueno, so…. I came up with this and I am quite happy with it and am sure it will last and function just fine.
After seeing the small space that needed taken up, I first thought silicone. Then that didn’t seem to be a good solution. I put the standard bushing in with the “outside” inside of the roll stop bracket and it fit well and would be a good replacement for a wore out stock unit, in fact, it is probably stiffer than a stocker would be if installed that way, but I wanted a nice solid roll stop so I did some “altering” of the Prothane #13-506 bushing.
Here is what I did. I wrapped the smaller area with 14ga speaker wire pairs (9" long apiece), which was a perfect fit, and slid the bushings in on both sides. It fit like a glove, no sloppiness what so ever. Pictures are worth a thousand words so I took plenty to show what I did.
Some may call it “rigged” but it is very solid and won’t wear out plus it can’t ever be seen, not that you can tell when you are finished doing this mod.
I hope this may help any other 1g Auto guys that need to replace that back roll stop and would like to have a solid or Urethane mount in its place, this WILL work!
Marty
And INSTALLED.....
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
