2G 1g nt 63mm throttle body help
DSM_GSX01
984
15
Jul 27, 2011
La Junta, Colorado
Yea i wanna find out if this is a 1g nt 63mm throttle boby i bought. How can i make sure? Were can i measure at? I have pictures also. I need to rebuild as soon as possible also.
That is a stock N/T throttle body. The blade diameter is 60mm same as a turbo throttle body.
No stock throttle bodies were 63mm, and neither is the one you posted (stock 1g N/T). All 1g (turbo and N/T) came with 60mm bores. The only way you'd have a 63mm bore is if you bought one specifically from Steve Monroe.
As I mentioned in the PM to you, a bored one will have a shiny/reflective bore and plate, just like the picture in post #2.
I measured the back side of throttle body and 59.55mm is what it says[DOUBLEPOST=1407968107][/DOUBLEPOST]So i guess its just a 60mm bore stock. I got it from guy and he said it was nt 63mm bore. Its a nt 60mm bore correct? And were is best place to get seals?
Yup, then someone "bored out" just the inlet. That is a stock 60mm throttle body, not a bored out 63mm unit that you'd get from Steve Monroe.
If you're looking for just seals, there are a few places. ExtremePSI, MachV, STM should all have at least the normal seals, if not some version of a metal cased/mil.spec seal. If you're looking for mil.spec seals, just buy them directly from the person who supplies them (Google it - there's a thread on EvoM about them and how to purchase).
