Resolved 1g No start from hell
Brian Drake
5
Nov 27, 2016
Neenah, Wisconsin
A Little background first. Bought the car running with a blown headgasket. Replaced the gasket and piston rings and rod bearings while I was in there. I've been through the no start list a dozen time. Timing is perfect. Cylinder leak down test came back good. Motor cranks over but nothing else. Checked spark with plugs out of the head. Tested coils for resistance. All good there. Getting 12v at the injectors and injectors click when bench tested. Tested fuel pump also good to go. Fuel filter not clogged. Resistor pack plugged in properly and tested good. Linkv3 shows good numbers for other sensors and ecu light goes off after 5 seconds and factory boost gauge centers as it should. Didn't touch the Cas while the head was out. I'm at a lose of what could be going on.
I havnt not tried unplugging the maf. Confirmed the plug wires are in the right order. Tested the pump by supplying it with direct power. I can hear it kick on then off when turning the motor over by hand. Starter went out trying to get it going. New one is waiting for me at work. I'll get it In tomorrow and pull the maf and try to start it on starting fluid
Starter didn't come in at work today so I was turning the motor over by hand key on with the coil pack unplugged and logging to see if the injectors were firing. Injectors are not firing and I'm now only getting 1.25v at the tps connector. Is it time to pull the harness and start inspecting it for shorts or broken wires?
not starting with maf unplugged or starting fluid. here's a log of my start attempt. thanks in advance for any help
it would appear i flip flopped the coils when i mounted them to a new bracket for mounting them with the cyclone. fired right up and ran great.
Rule of thumb. If you messed with something and it doesnt run now. Go back to that item.
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
