Ludachris
Founder & Zookeeper
- 8,878
- 4,725
- Nov 12, 2001
Newcastle,
California
I believe a FWD is different, but on the 1G AWD, you have a brace that runs from tow hook to tow hook under the car, bolting up to the sub frame. That brace has the front motor mount attached to it and has a couple sub frame braces attached to it. It's obviously a critical piece. However, there is also a cross member integrated into the sub frame running parallel to that brace which holds the wiring harness and has the lower radiator mounting tabs attached. It's almost as if it's redundant due to that other brace. On a FWD, it seems the forward running sub frame brace connects to this cross member, but not on a AWD. Here's a photo of the cross member (U-shaped) I'm talking about:
So, what do you think? Can it be safely removed on a car that sees a lot of track time (road course)? Or would it cause some flex issues? I'm planning on replacing the other brace that runs parallel with a tubular version with an integrated motor mount and provisions for the radiator mounts and forward running sub frame braces. I figured if I just used a little thicker bar, it would be strong enough to prevent any flex that might occur from removing the cross member.
Thoughts?
Thoughts?
....NOW that is weight reduction!!
