- Thread starter
- #76
Anfurnyy
Supporting Member
- 1,493
- 1,910
- Jul 4, 2020
Rapid City,
South Dakota
Took the car out for another cruise yesterday, seems like I've got partial throttle and cruise pretty good (or not, you tell me). Starting working on cleaning up the transition into boost. It definitely needs some work. It's pretty rich up top, running like 8s on the wideband at anything above 5 psi.
Also need to work on sorting out my open loop thresholds too and get them where I actually want them to be. I'm a little dense and am having some issues understand exactly where these should be set at so that I'm still in closed loop while cruise, and in open loop when I need to be as well.
Also out while cruising I think I was in 3rd just cruising and the damn power cut again, twice. It only does it for literally one second, I can hear the MPI relay click once, the dash CEL pops up and then goes away and the car continues running. I really need to figure out what the hell is causing that.. that should probably be the next thing I dig into so I'm not mid pull and lose power.
