1g Auto - power questions
Rumbarger
Jul 14, 2007
Galion, Ohio
Anybody know - How much smaller are the turbo/injectors in my 1g Auto?
- How much power can they support?
I've also read that the ECU in the auto is set up for these smaller parts, making more low-end torque, Is this correct and how big is the difference?
Any educated replies would be greatly appreciated.
I had a JDM VR4 auto, in which I removed the broken TD04H and fitted a S16g. The S16g uses a different size water banjo bolts, which requires you to change the pipe from the waterpump pipe, and also use the S16g line that goes to the thermostat housing. It may be possible to ream out the banjos, but in any case you will still need the larger S16g banjo bolts. Both the oil feed and the oil return are the same, though.
I had read that somewhere,but I haven't been able to find out where. I wonder if I could use the stock lines off a m/t with 16g turbo?
my small 16g on a bone stock setup spools to 15psi by 2600rpms.
That is sweet!! I didn't realize the stock turbo could spool up faster than the Evo,and to that extent! Def what I'm looking for:thumb:
  • For sale 2g sunroof shade cover
    I have 5 sets of these. They are freshly re upholstered. The material I used was black suede. I...
    • Jose gonzalez
  • Wanted 2g ISO Rear Pass EDM Tail light
    Looking for only a passenger rear EDM tail light for my 2g. Please lmk if you have one lying...
    • Gabriel Pena
  • Wanted 4G63 ISO built short block
    Looking for either a 7 bolt split thrust or 6 bolt
    • Gabriel Pena
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale 2g 1996 Eagle Talon TSI AWD
    I have a 96 Eagle Talon AWD standard tranny for sale. The car still ran when I parked it. I had...
    • eli1977
