1g 7bolt, Help with timing side installation.
g4ebguy90
2,001
3
Mar 9, 2011
Rockford, Illinois
hi guys im rebuilding a 1g 7bolt. Problem is, its been so long since i took it apart that I dont remember what bolts went to were. And my shop manual and haynes manual seem to have the wrong information for the front case. Like its for a 6 bolt or something.
HEres a pic, any help would be nice.
Thread pitch for all M6 bolts is 1.00mm, M8 bolts is 1.25mm, M10 bolts is 1.25mm.
FRONT COVER (CASE) OR OIL PUMP AND OIL FILTER HOUSING OR BRACKET:
1 - 8 x 20; 1, 2, and 6 are the same
2 - 8 x 20
3 - 8 x 55; timing tensioner
4 - 8 x 55; timing tensioner
5 - 8 x 20 or 22
6 - 8 x 20
Between 6 and 7, from the top, there is a plug. It is a 3/8" BSPT thread, just like that found on the large ports of the oil filter and thermostat housings.
7 - 8 x 40
8 - 8 x 25
9 - 8 x 32
10 - 8 x 40; oil filter housing or bracket
11 - 8 x 65; oil filter housing or bracket
12 - 8 x 75; oil filter housing or bracket
13 - 8 x 65; oil filter housing or bracket
14 - 8 x 45; for balance shaft belt tensioner pulley
15 - See Timing Belt Cover below, B
16 - Unused on 1G, for 2G crank sensor, 6 x 16
17 - See Timing Belt Cover below, C
18 - Unused on 1G, for 2G crank sensor, 6 x 16
19 - See Timing Belt Cover below, D
20 - See Timing Belt Cover below, B
21 - 8 x 118; Alternator Mounting Pivot Bolt, through hole
WATER PUMP AND ENGINE MOUNT BRACKET:
1 - 8 x 30
2 - 8 x 22
3 - 8 x 14
4 - 8 x 28
5 - 8 x 65; through hole
1 - 10 x 25; use sealant!
2 - 10 x 22; use sealant!
Black - Not used; hole is covered by engine mount bracket
Blue - See Front Cover above
TIMING BELT COVER:
