Vladimir
- 416
- 139
- Apr 28, 2010
Winthrop harbor,
Illinois
Got this ECU out of my old parts car. IC106 burned, I'm assuming it's only responsible for boost control function and should not affect anything else, right?
There is a booster wire in the back of the board that is broken under 106 (I assume ECMtunning soldered it to power the ic106) but I am not sure. What would even be the point of having 106 if they converted the whole ECU to DSMLink v3?
Could it be that the board passes power through one of the pins under 106 and since it burned, ECMtuning just used a booster wire to jump power to a particular pin under it, bypassing and not fixing 106 since it's pretty useless? And the only reason for the booster wire is to power another part of some other circuits?
Geek squad, it's time to shine. Who got the knowledge??!
