1999 and 1995 awd transmission
j-jamrod
83
Nov 8, 2007
Baltimore, Maryland
i have a question mines is a 1995 awd, i recently found one AWD transmission from a 1999, are this transmissions the same in the gear ratio???
I personaly don't kno, but did u blow your 95 AWD system or are you just looking for a faster gear ratio?
95-96 same. 97-99 has a different final drive ratio.
You need a 97-99 tcase for it to just drop in.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/GK6d-BFMW84&rel=0&color1=0xb1b1b1&color2=0xcfcfcf&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/GK6d-BFMW84&rel=0&color1=0xb1b1b1&color2=0xcfcfcf&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
My mistake, forgot that link didn't specify separate 2Gs. I was just searching for that same video projectgs.
mine just blow, and i found a good dela in a used 1999 with out transfer case, but i m sure i will have problems with the gear ratio...
how about the rear end?? i think this one will be afected to..., probably have to change the rear end also , only for the gear ratio
