1995 awd transmission auto problem
dustin560
32
May 3, 2011
rantoul, Illinois
picked up a 1995 awd talon only had 105k with a broken timing belt car was all stock besides a 1g cam sensor. Well long story shop I put a 6bolt block with a 7 bolt head I did buy the kiggly spacer. Here is the problem.
Runs fine but revers works fine. drive the car will not move. L the car will move at like 3k then after its going I can put it in 2 and then drive. Fluid is good. also has no power car hits 12 psi on my gauge I put in. but its not moving iv had other turbo eclipses.
Only mods I have done besides the rebuild is after the car was put together I had to get a ecu I did pull it out of a 1995 gst auto. I got this because the ecu would not ground the mfi relay.
trans bad? I did take the valve body off and clean it and put a new filter on.
ill go over it again but im 99% sure also when I put the valve body back in I made sure the pin was aliened.
Well I bought the car with the sensor on it. The pins haven't been switched but from what is read it should just though a random miss code
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
