1997-99 headlight connectors.
MJ'sbtch82
Feb 10, 2013
La Center, Washington
Does anyone know where I can get ahold of 97-99 headlight connectors/plugs? I'm swapping from 95 headlights and the plugs are different, I called Mitsubishi and they didn't have any help to offer. I appreciate any help.
I did a 2ga to 2gb front bumper swap and everything was direct swap and all the connectors were perfectly interchangeable for both of them sides as well as the bulb sockets. Are your headlights all OEM?
Only the early 95's have different connector ends bro. I had the same issue and just took the connector off my old headlight and hard wires it to the new so it was plug and play. You can basically use any 2 connectors you want either the early 95 or later ones, just have to hard wire in both matching ends. Hope that helps bro!! :)
I don't know if I can agree with only 95's have different connector ends because it was my 95 that I put the 2gb front on. My 97 is already a 2gb so I would be trying to swap it to 2gb. Maybe it was the early 95"s kind of like the vented rear disc stuff. My 95 is a later model 95 with the solid rear disc as well and the headlights are interchangeable. Bro
