1G 1990 wiring harness question
v8s_are_slow
2,824
280
Sep 30, 2002
Panama City, Florida
I'm being told that a 90 harness is different than the 91-94's. Does that pertain to both the engine harness AND the interior harness to the ECU as well? Is that the sane harness? Or? Thanks!!!
Hey Scott your back I forgot I think just the auto body connector is different pinout. The ECU connectors don't matter just pin 6 and 14 you change up if your switching ECUs . Example the 91 ECU you switch the pins for the ECU for them MAF if I'm correct, Craig can confirm this.
Interior harness is different as is the engine harness. Couple different style connectors, and the 90's have a unique CAS and PTU plug, as well as a "tach filter" for the coilpack. On the interior, the dash harness is different in a couple spots as well.
