1990 oil filter position relative to O2?
What is the sandwich for? I thought the sandwich was an aftermarket thing for people who want to add an oil cooler, but heck I don't know.
Gary
The 90s have the external air/oil cooler . The sandwich on the 91+ is a PITA oil/water cooler that can crush if you screw the filter on too tight, and replaced the external cooler from the 90. Both versions are "sideways" mounted. Are you asking for a specific reason or for general knowledge?
What's going on is I'm about to spend a bunch of money on a T3 manifold and O2 housing kit that is made for DSMs. I'm trying to do my homework by sniffing out all the possible fit problems, which there are a lot of. One is the amount of clearance between the O2 housing and the oil filter. If it turns out that I can't even change my oil filter without taking the O2 pipe off or some problem like that I'm going to be pissed. If I know that the oil filter position on my car is the same as the other years, or farther away from the O2, then I'll be more confident that this thing will fit ok. But if the 1990 filter comes closer to the O2 than the other years I'm going to have to do whatever it takes to convince myself it's ok before buying.
Gary
    • Sdcryan1
