1G 1990 DSM tach jumping.
blazekid71
Nov 29, 2021
Utica, Indiana
1990 GSX. Cleaned all grounds. Added 2 ground straps. Changed coil pack, changed gauge cluster and bypassed noise filter as in above reference. Tachometer works fine until engine is under a load after 4000rpm then Tach starts jumping around then drops out. Any help would be appreciated. If I need to order a new tach filter and take out jumper on filter harness I will do so. Thanks Scott
