17x9 +45 Enkie RPF1 offset on a 1g?
Viva
299
Jan 14, 2011
Findlay, Ohio
Alrighty so I found a set of enkie rpf1 17x9 +45 offset (gold). Has anyone fit these on there 1g awd? I've searched for threads but no luck. If they fit in the fenders well what tires should I get? I'm not going tto have a lot of track time so street tires will be applied (Cooper zeons zt) to be specific. I am not sure what size tires. I don't want to go to a 8 inch wide wheel. Thanks guys!
Did you use the offset calculator linked MANY times in the forums? +45 with a 9"? Doubt it, but I'd check the calculator.
Did I mention to check the calculator?
Without checking the calculator and knowing tire sizes, drop, etc...I'd assume a +30ish ofset would be the sweet spot.
Thanks buddy!,
where is the calculater on the site I been looking.
Well unfortunately I can't get 17x9 with anything but 45mm offset. The lowest is a 43mm. I was directed to get Cooper zeons. 215/40/17. Then I saw a fella have 255/40/17 falkens ??? This is from dsmtalk, I'm not sure if I'm allowed to put the link up or not. (Conflict of interest)? If not someone delete it pronto.
Picture request: Enkei RPF1 or NTO3+M or RPMII wheels on a 1G. - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Just photos. He said has spacers 5mm and 8mm +?
I know this may be silly, but why do you want 9" width?
I seen the rpf1 setup on a 1g eclipse it was 17x9 and had the most aggressive stance ever. He said they were 9" , I don't know him I met him at a gas station in new Jersey. I'm not sure if he really had 9 or 8" inch wide so was gonna double check with everyone here.
Like that car. It has the size you're looking for according to the owner. His name is TSIDRIFT1. You can look up his profile.
I decided 17x8 with 215/40/17 falkens should be good for time trials.
It was exactly on the border of NY. we were headed to rohde island . Wrong turn all I knew i was in NJ LOL
I used the calculator given and that's what lines up.... what's the reason for it if you disagree, yet I have no flipping idea which tire I should select that's not 110 dollars or more.
Thank you Landoo, and I have 215/40/17 on 17x9 on eagle alloys right now. It has a "euro"stretch but I'm selling that set for 850
Disagree my friend there rugged looking. I'm not into "cute or pretty" wheels.
I'm running 245/40 R17 on a 17x8 +38 (EVO9) and they look really nice on a 2GB
Yoy said u wanr stance so? I got 17x9 +35 rpf1s and they look way different.
You wont have stance if u pick the wrong offset or wheel width. And why run 215s on a 9? If you want little strech go with 235s on a 9 or 225 on a 8.
I I don't really care for the stretch tbh
