Enkei RPF1 17X8 +45 Offset Questions
BoostedinSoFla
1,950
19
Nov 1, 2006
South Florida, Florida
So I'm dead set on getting gold RPF1's, the problem is they're not available in +35 offset for that size wheel. They're only available in +45.
I have Evo 8 Brembos that I also need to clear and have confirmed that the 17X8 +35 fits fine and clears the Brembos. Will the +45 work? I'm NOT the best when it comes to wheel fitment
With that size wheel and offset and assuming a 235/45/17 tire size you would be most likely not be able clear the suspension in the rear. You would have about a 1mm clearance, but depending on tire manufacturer it could have no clearance at all.
