17x8" +35mm offset Rota Boost Wheels with 225/45/17 - Comments?
TSIsean
113
Jan 22, 2004
Lasalle,
I'm considering getting some gunmetal ROTA Boost Wheels in 17" with 225/45/17 tires from MACH III (http://www.machiii.net/wheels/boost.html) 5x114.3 obviously and a 35mm offset. The tire will most likely be BFG G-Force KDW. The wheels weigh in at an accecptable 18lbs a corner.
Anyone have any comments or problems they might see on this new setup? I use my car primarily for drag racing, but do enjoy a nice handleing/looking rim-tire combo.
Right now I'm running my friends 17" Chrysler Intepid R/T rims with 245/45/17 and they don't rub or anything, but I'm not sure of the offset on the wheels. I should be ok. I'm just wondering if the offset is correct for my application on these Rota's there is an available 48 offset as well.
Yeh but as long as they match all the specs for my car it shoulden't matter.
I wouldn't run such a narrow tire on an 8" wide wheel. Step up to a 235/45 or a 245/40 you'll notice a difference for sure. :)
I have evo wheels on my 1g (i can't remember if they're 38 or 35mm) and they stick out a tiny bit in the front, but no rubbing (235/45's)
You might have a tiny bit of rubbing, but nothing you can't deal with.
In the end result I have ended up ordering 235/45/17 Yokohama AVS ES 100's for the Rota Boosts.
I'll post pics and results once the whole setup is on the car in the next week or two.
Thanks for all the advice.
  • Wanted 6 bolt NT water pipe
    • chrisman287
