10.8 @ 134 with Hx40
badman21
47
Dec 16, 2005
Rosedale, New York
Finally made it to the track and made a decent pass unfortunatly i was kicked off due to lacking of saftey equipment. I am going to try to back it you another track sometime next week. I have no video cause my girl messed up but here is the time slip. Still have alot to learn about the car.
Good 60' time, what are your mods? Post up a vid of the next time you go
Gotta love the hand writtne time slips now thats OG for sure!
Nice times. Judging by the mods its got a lot more in it! I bet an auto w trans brake could break you into the 9.99 bracket :thumb:
Kolby
I take it this is his 685whp stroker hx40 setup but I'm not sure about boost. Goos times man. It's about time one us got into the 10's so these garret guys can suck it. You know once you break the ice everyone will follow suite. Hopefully some of us will break into the 9's too :sneaky:
we'll leave that up to you HX-52 guys:hellyeah:
Nice run.Hope i can put up some good numbers with my BW.
Good job, Badman. You are right on the money. This timeslip, goes perfect with the speed you had. Good luck.
BTW which Holset is that:7/8 blade, what housing anf what boost level??? Thanks.
Thanks guy I appreciate all the support i just want to say that Turbo Sharky wouldn't exist if it wasn't for my tuner Waynespeed, who is a good guy and a wicked tuner. He helped me with my setup and told me that these holset turbos were nothing to play with. Here is a pic of the car on my way to the track.
street tires or drag radials? And about how much boost were ya running? Curious to see where to match my hx40 up with....where you on race gas/pump or e85?
I should be picking up my holset 35x tomorrow. Damn I can't wait for the fun to begin.
the car weights 3140 with me in it and i am 210 and that was 40psi I took it easy the first pass trying not to break cause i have stock axles, unfortunately i was unable to get a second pass. I just need to get my 60' down and see what happens.
Beatuiful car. Can you post up a dyno sheet please. I just want to see spool times on your setup. Since mine, and yours are very similar.
James :dsm::talon::laser:
40psi on a 2.3? You must be running some pretty conservative timing numbers.
