014 code on dsm link
Factoryride250
Feb 8, 2011
PA, Pennsylvania
So when i start my car it fires for 3 seconds roughly then shuts off. Code that shows up on my link is (014 throttle position circuit malfunction).My TPS wont read over 29% throttle and reads 1.90volts at WOT and 0 volts when closed.Any suggestions please?:confused:
My car was running fine. I installed my wideband and tucked the ecu away under center console went to start it and this is what i got.I changed TPS still same readings.
Sounds like a bad connection from you harness to your ECU and when you moved the ECU it wiggled the wire. The TPS is Pin #19 on the ECU. If you pull the wire out of the connector you can tighten the end with a needle so it makes a better connection with the ECU.
I had a similar problem recently. Hope this helps!
Thanks for the help ill be doing this tomorrow to see if thats the problem.Ill let you know how it goes hopefully its this simple.Thanks
i tested all Continuity to the following three:
Tps +5v sensor green/red to ecu pin 23 [good]
Tps ground green/black to ecu pin 17 and 24 [good]
Tps output green/white to ecu pin 19 [good]
That leaves me with what a bad tps if im still getting those readings? All ecu connections look good as well as tps plug. when i changed out tps the one i changed it with was used also not sure if its good or not. Im going to have to find a good Tps off running car to find out for sure.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
