- Thread starter
- #151
spyderdrifter
- 5,426
- 860
- Jul 11, 2009
Somewhere in,
Colorado
Much Needed Win...
I've been working on little things lately. Since the Shootout, I've noticed some power hesitations (that I'm still looking into), and fixing boost leaks. Thanks to DustyLandrum, I finally got new throttle body gaskets from AO Customs. Even bought a new silicon gasket for my turbo j-pipe since I blew that gasket out at the Shootout. Turns out one of the bolts backed out and left the engine bay. Replaced those three gaskets and installed the FMIC that came with the car. Just had to get a few extra pipes to make it work out. Repositioned my oil cooler to accommodate the pipe routing, and will finally get the cooler lines actually connected with my next oil change. I changed my oil as well, for the first time since dropping in the engine. I have around 220 miles on the engine, and the oil came out pretty clean. I haven't opened up the filter yet though. Went on a test drive after getting the new gaskets and the FMIC installed and I'm still having the weird power hesitation. Normal driving seemed fine though. At stop lights though, the idle was surging quite a bit. So today I decided to replace the BISS and its o-ring. Already had new ones so I figured why not. While letting the car warm up, I decided to connect my scanner to the OBD port. No real reason, just decided to do it. I finally got it to communicate with the ECU! I just bought a new harness from another member here and won't have that until this weekend, but this proves the harness does work, just need to figure out why it hasn't until now. Found out I have 3 trouble codes all related to idle control, so that explains a lot on its own. I ended up swapping the IAC and MDP sensors with spares I had. That along with the BISS have stabilized the idle for now with no surging. More later...
