1G Turbo woes
Badge023
73
72
Nov 9, 2025
Ewing, New Jersey
So, here’s where I’m at. Chasing out an exhaust leak at the manifold and found that the O2 housing gasket was blown out. Got a good housing, pulled the cracked one off. Only problem is that in talking the bolts out, the threads on the exhaust side of the turbo came out too. Yes, I sprayed them for a week before I even attempted. It was the will of the Mitsubishi gods. From what I was able to research on the site, I believe I have a 14b. Casting number on the back of the housing is 78-11830. I can have a machine shop fix the threads, hopefully. My questions are, does anyone know of a place that can rebuild the turbo? Are parts available? There’s a good amount of movement in the shaft. The vanes look okay. I’ve only removed the exhaust side so far. Thought I’d reach out to the guys with 30 years into these cars because I’m bored with seeing 16G upgrade kits in every search. I don’t want to upgrade and then have to follow with all the ancillary upgrades that come next. Happy with stock. Since I'm relatively new to the turbo arena, is it the shaft that wears or the bearings? Thanks in advance.
Justin is an amazing turbo man!
2024 is what i think i was able to see. I can guarantee he is over on FB. My son seen a post recently. Great turbo builder, IDC where he's at.
My son is Matt. He's built several turbos for me and my son.
Facebook.com/justurbos
Idt you will catch him except every now and then over here. If you need work or a good turbo for your specific needs, he will help fix you up. He signs his units also so he knows it was his his unit. I had him do a Frankenstein 20g and that thing was a great turbo before I went to a 60mm size, that he built and I run also. 👍
I don't have FB myself but my sons show me different posts or help.
This is my E16g that I have of his.
I'll send a DM on FB and see.
I think that in this instance, it will help you out.
  • For sale S90 TB 70mm
    Purchased this month from STM. Comes with the FIAV block off plate that was already installed...
    • Bedicine
  • Wanted 1g Need 1g AC tensioner bracket
    I am in need of 1g AC tensioner bracket - looking for complete with bolts. Recently bought 92...
    • JLavetsky
    • steelcurtaindsm
    • Syclone#334
