pauleyman
DSM Wiseman
- 11,404
- 5,295
- Nov 19, 2011
oklahoma city,
Oklahoma
I will concur. You can shift it into first (engine off) and compare the position at the trans to where it lands if you shift it no cables. If your in car shifter is worn then the atvtrans shifter may boy be moving as much as it should.I will also suggest new shifter bushings. They are very reasonable and will make an old shifter feel new again.
2G DSM 95-99 Shifter Bushings | DSM 3D Creations https://share.google/Y53p77x9s72FUqckB
