2G SRS diagnostics today
Justin DuBois
DSM Wiseman
3,292
3,267
Aug 15, 2019
Oakland, California
I have one of the early 95' 2G's and the SRS light is on solid. All the factory original SRS equipment is in place. The internet says the SRS system is independent, and the normal approach at grounding a pin the in OBD-II port will not work. A MUT-II or MUT-III scanner is recommended to clear the code.
The internet also thinks the SRS computer may suffer from leaking CAPS same as the fatory ECU.
What is available today to help pinpoint the failure, and who works on these boards?
I had this issue a few years back. IIRC, I thought I may have accidentally powered on the car without the airbag plugged in which I read would turn the light on until reset. I couldn't get my hands on a scanner that would reset it, so I just bought a used replacement ECU which didn't fix it. It turned out to be a wire in the clockspring that had gone bad. I think I was able to use a multimeter to check the clockspring wires.
In my experience the module is always the fault underneath the center console. I have typically just unplugged them and the light will turn off on its own
A few months ago there was some one in Europe in the newbie forum trying to diagnose it with a mut2 tool, I do not recall if he resolved the situation but he needed the system functional to pass inspection (im not sure how they would verify it functioned if the light was off)
There is a magic code, that I don't know, that is required to reset the SRS light that the MUT tools know how to send. The 3000GT guys figured it out by snooping the diag bus when resetting it and made a tool to do so but wanted too much money for me to be interested in buying one.
On the early 3000GT cars there was a way to cycle the ignition switch that sometimes worked.
This only works on 92's according to the 92-96 3S manual.
NOTE
1. From 1993 model, the SRS warning light illuminates
also when the battery voltage drops. In that case,
the SRS warning light goes out if the battery voltage
returns to the normal level.
2. On 1992 model, if the vehicle has a discharged battery
or battery power supply (multi-purpose fuses No. 11
or No. 18) is disconnected with the ignition key in
the “ON” position, the SRS warning light will continue
to illuminate even after the battery is recharged or
the fuses are replaced in their original positions. In
this case, the SRS warning light can be extinguished
by turning the ignition switch ON and OFF 10 times.
@USMCGSX recommends scanner Autel Maxilink ML619
I’m going to get one and try it out - it looks like it can talk ABS and SRS
SRS diags found fault code 25 - Passenger Airbag squib connection fault.
I disconnected the ground to the battery, waited 10-15min. Disconnected/Connected the red connector at the left corner behind the glove box (it looked fine) and then reconnected the battery ground and checked with the scanner again.
The fault code was still there, so I cleared it - and the light stayed out. Re-reading the codes - it indicated the system passed all tests.
That was handy!
The ABS light is still on, but that's expected when none of the wheel sensors are hooked up.
Follow up - Autel Maxilink ML619 is not communicating with the ABS system. I think this is another early 95’ specific issue. Thats what happens when you go to market with new tech before standards are fully implemented
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
