Justin DuBois
DSM Wiseman
- 3,416
- 3,398
- Aug 15, 2019
Oakland,
California
I have one of the early 95' 2G's and the SRS light is on solid. All the factory original SRS equipment is in place. The internet says the SRS system is independent, and the normal approach at grounding a pin the in OBD-II port will not work. A MUT-II or MUT-III scanner is recommended to clear the code.
The internet also thinks the SRS computer may suffer from leaking CAPS same as the fatory ECU.
What is available today to help pinpoint the failure, and who works on these boards?
