Activity Feed
Live updates
  • We're on Boost replied to the thread 6266 Build or Bust.
    · 695 70,747
    Right.That's what I've been told too, about the 10 micron stainless mesh filters. Was told that by either STM or by Fuelab, can't remember which.Thanks for the element pic. The only fuel filter off my car that I've seen the inside of was...
  • Jafro replied to the thread 22/1000 Galant VR-4 saved from junkyard..
    · 54 9,088
    Boy did I miss the boat on this. You found gold in that junkyard, brother!What's currently left of the parts car? Looking for body trim, maybe a door, and I need a driver's side fender no matter what color it is (for anyone else who's...
  • jdxnc replied to the thread What did you do to your DSM today?.
    · 11,918 756,044
    Got my block back from the machine shop Friday, started putting it together yesterdayYou must be registered to see element.
  • steve replied to the thread 1G No start car issue.
    · 23 943
    There was that too, plus backfiring usually means timing issues on a normal car.
  • steve replied to the thread 2G Alternator Plug needed?.
    · 14 976
    Let us know if this worked for you.
  • dwb replied to the thread 1G Clutch Bleed Secrets.
    · 12 1,071
    What happens if you bump the starter with it in 1st and clutch pressed? Does it slip or lurch forward?I don't have measurements but here is mine with a new clutch and flywheel (video at the bottom of this post) Post in thread '1991 TSi AWD' You...
  • enriquez2000 replied to the thread 1G No start car issue.
    · 23 943
    Well I can't get the marks to line up with crank at TDC, not sure how it happened. It went in timed perfectly and drove fine until it sat.I'll have to dig into it and hope the valves survived. The Harbor Freight gauge notoriously reads 10psi...
    · 23 943
    That might answer why the compression numbers are so low given he's got 10.5:1 Wiseco's. I scratched my head a bit at first but wrote it off to altitude, being a cold engine, and maybe big cams.
  • 19Eclipse90 replied to the thread Spyder 4g64 EGR Delete help.
    · 4 498
    You must be registered to see element.Effectively, what you need to keep is the line from the fuel pressure regulator to the intake manifold.Block the EGR valve at the intake manifold, cap the ports on the throttle body and P port on the...
  • Furiyous replied to the thread 2G Factory keyless entry help.
    · 32 1,637
    Installed the new keyless entry module. Same result. Only lock and panic are working.I think my last ditch effort is going to be trying those aftermarket fobs you suggested @chrysler kid in hopes that the unlock button on this OEM remote is...
  • 19Eclipse90 replied to the thread 3D Parts Files.
    · 120 29,825
    1G FWD Clutch Release CylinderYou must be registered to see element.You must be registered to see element.All shown parts should be in the .zip file.
  • C-note89ky replied to the thread What did you do to your DSM today?.
    · 11,918 756,044
    Little DSM meet in my driveway.You must be registered to see element.You must be registered to see element.You must be registered to see element.You must be registered to see element.
  • MindBlowin03 replied to the thread What did you do to your DSM today?.
    · 11,918 756,044
    I used the factory two brackets. I modified them a little bit to get it perfect.
  • dwdsm posted the thread 2013 Supercharged BRZ in Non-DSM Build Journals.
    This is the Build Thread for You must be registered to see element.. Reply below.
  • dwdsm added a vehicle profile titled 2013 Supercharged BRZ to the Misc Vehicles section.
  • SimpleSecurity replied to the thread What did you do to your DSM today?.
    · 11,918 756,044
    how did you mount that screen? Trying to put a raspberry pi and touch screen there but haven’t found a way to mount it
  • pauleyman replied to the thread 1G No start car issue.
    · 23 943
    Doesn't matter. Cam gears always travel aligned. You can see at a glance they're not together. Thats kind of unclear...imagine when the number 1 is at TDC the gears point straight up. So whatever position one is in the other is in the exact same...
  • 1cleangsx replied to the thread CrackedDSM's boring new project (420a).
    · 138 9,277
    I think it depends on if it’s rewired or not:thumb:
  • DSMPT replied to the thread 1G No start car issue.
    · 23 943
    That screen shot is from your video. Doesn't matter if it was at TDC or not to check the cam phase.Assuming that those white markers on cam gears are the factory horizontal timing marks, I could confirm it more clearly. Your timing is off. The...
    · 23 943
    It was a video and its not at top dead center at allHeres a better view of cams... ill have to get it in the air for aligning the crankYou must be registered to see element.
