Activity Feed
Live updates
  • DSMPT replied to the thread 1G No start car issue.
    · 23 943
    Could be the timing jumped or so for some reason. Since we can't see the crank position in the video, we can't tell how much amount exactly off, but anyways at least it seems 3 cam gear teeth out of phase in that video. That's we can say for sure.
  • pauleyman replied to the thread 1G No start car issue.
    · 23 943
    If this is a still shot the timing is definately off. First order is correct it and run a leakdown.
  • enriquez2000 replied to the thread 1G No start car issue.
    · 23 943
    It ran fine before winter... not sure how it would be out of time now. But who knowsI unplugged the map and no gauge change just stayed -6 so might be a gauge issue since that sends the reading to link.
    · 23 943
    Hard to tell by only that video, but I can hear and see that the mechanical valve timing seems to be off, like at least cams are about 3 teeth out of phase. Should double check for the timing. You must be registered to see element.
  • TrevorHunt posted the thread 91 Eagle Talon in DSM Build Journals.
    This is the Build Thread for You must be registered to see element.. Reply below.
  • TrevorHunt added a vehicle profile titled 91 Eagle Talon to the 1G DSM section.
  • 1cleangsx replied to the thread 6266 Build or Bust.
    · 695 70,750
    You must be registered to see element.No goo on the filter, lots of specs tho, it’s definitely dirty, I feel like maintaining a high output car on e85 will always be higher maintenance, but its worth it:rocks:
    · 695 70,750
    The goo was in the outlet end, with the end of that feed line exposed to air after being disconnected from the rail, the mystery is if it was there before I pulled the engine/rail. The 10 micron filter connects to the inlet of the filter housing...
    · 23 943
    the gauge itself shows -5(ish) with key on and I think it goes to -7 when cranking.Ive heard these gm sensors go bad often if the nipple doesnt point down.That would sure be an easy fixYou must be registered to see element.
  • Nightmare2020 replied to the thread Spyder 4g64 EGR Delete help.
    · 4 498
    I can get pics tomorrow
  • GIB replied to the thread Spyder 4g64 EGR Delete help.
    · 4 498
    Do you have an engine picture? 2g 4g64 cars are very similar to the 4g63, just different heads, a few more coolant holes in the block and 6mm taller than 4g63.
  • bastarddsm replied to the thread Group buy: Stronger 5 speed gears!.
    · 79 14,710
    Yeah, it is a mess right now for sure. And then I wonder if everyone is going to get hit with a tariff charge when/if they finally do get here.
  • jdxnc replied to the thread Group buy: Stronger 5 speed gears!.
    · 79 14,710
    No one wants to deal with all the extra bullshit to ship to the US now, every item needs an HS code, which can be a PITA to find the correct 10 digit code that corresponded to the type of product. I just had to figure it out for a viscous coupler...
  • steve replied to the thread 1G No start car issue.
    · 23 943
    So before you start cranking the MAP should measure 0 psi or inHG and your says -6.1. With your mods and Ft. Collins altitude I don't have any idea what your cranking vacuum should look like but I know it shouldn't be the same as when you're not...
  • techboy replied to the thread Galant VR-4 Restoration #129/1458.
    · 203 38,088
    I made a comment in one of my previous posts that I knew we had purchased brake lines for this car years ago, but I couldn't find them. Found them. Finally.You must be registered to see element.With that, we are able to install and wrap...
  • rdeis replied to the thread 1G Clutch Bleed Secrets.
    · 12 1,072
    Nope, no sign of bubbles anymore,,so that’s good, but it’s still not releasing.I’m measuring 10mm of motion on the end of the clutch fork. How much travel should there be?You must be registered to see element.You must be registered to see...
  • jersygsx posted a question on the classified ad Wanted WTB : 1g cylinder head.
    If you’re still looking for a cylinder head, I just listed one
  • We're on Boost replied to the thread 6266 Build or Bust.
    · 695 70,750
    Thanks for the goo pics. I haven't checked my filter from 2022 yet. Are we looking at both ends of the filter housing there? Goo in both ends? How did the actual element look? How long did the car sit anyway?
  • jdxnc replied to the thread What did you do to your DSM today?.
    · 11,918 756,112
    Every single shift. 20 psi on the leave at 6250 2-step, running out to 40 psi.You must be registered to see element.
  • We're on Boost replied to the thread Street Build Red Redemption.
    · 124 11,252
    Looks like it fits together real nice but clearance to the alternator, how is that? Will you be able to put an O2 sensor in there or would it run into something?
