Activity Feed
Live updates
  • opn0 replied to the thread ForcedFour Time Capsule.
    · 37 3,195
    I drove the car to work earlier, and on the drive home, I noticed that the transmission was slipping. It wouldn't catch when I was giving it gas at low RPMs. I thought it was weird. Got home, parked the car.An hour ago, I had to leave to go...
  • enriquez2000 replied to the thread 1G No start car issue.
    · 23 947
    @steve heres a new log... the wideband is staying engaged the whole time. I put in this gm style 4 bar to test the map(it could still be questionable), What vacuum should the car be seeing at cranking.If feels like it wants to start so bad it...
  • rdeis replied to the thread 1G Clutch Bleed Secrets.
    · 12 1,076
    Aha!! There’s a really, really small leak at the flare joint to the slave.I had to have the system fully bled, and closed up, AND have a buddy pushing on the clutch pedal to see it.Small enough that it’s really hard to push fluid out, but...
    · 12 1,076
    fixed the pump up problem, so the master is properly adjusted now, and still no joy.This is really wierd.
    · 23 947
    The wideband goes into warmup mode for some reason when cranking... i figured thats the reason.MaP was suggested by a friend so I have a spare im going to try.My fear is you might be right about mice. Itll be under dash if so.... let the fun...
  • Turbski91 replied to the thread Street Build Red Redemption.
    · 124 11,253
    Still just stacking parts. Havnt had a lot of time lately to work on my own cars, but the time will come. The o2 housing and waste gate have arrivedYou must be registered to see element.You must be registered to see element.
  • We're on Boost replied to the thread Group buy: Stronger 5 speed gears!.
    · 79 14,710
    For people who have bought in during the last 2 years, it's been kind of like an investment in the Australian Dollar, which has turned out pretty OK so far. Check it out - Peak USD to AUD buying power was in around January of 2025. Was pretty...
  • dwdsm replied to the thread 2G Alternator Plug needed?.
    · 14 976
    Ah yeah I crimped them right up against both the diode and the resistor. Made it real easy to crimp. Just had to strip a bunch more then usual.
  • steve replied to the thread 1G No start car issue.
    · 23 947
    Check the hose to your MAP sensor and its wiring. It's not showing normal vacuum while you’re cranking.Peddling the throttle isn't going to help it start and I would think you’re almost 10ms IPW with those huge injectors even on E85 is a lot...
  • Furiyous replied to the thread 2G Factory keyless entry help.
    · 32 1,641
    I think it wasn't showing for me because I had my preference set for US only and that is listed in China.I just ordered 2 for the hell of it. lol.I also got the new Keyless Entry Module in, going to work on it tomorrow and see what happens.
  • Figured out the problem - there was ferrous "dust" on the two front ABS sensors. After removing it the car behaves normally.
  • Kid Boost replied to the thread What did you do to your DSM today?.
    · 11,918 756,227
    Nice.....its looks almost like my valve cover. I just have an fittings on mine and shaved the lines flat.When I got my transmission built I got 4 spider and its been great...cant complain.
  • 1cleangsx replied to the thread 6266 Build or Bust.
    · 695 70,771
    Hey guys, figured I’d do a little update of what I’ve done the last few weeks which really isn’t much LOL, a couple weeks ago I decided to check my fuel filter element and I’m glad I did! I found the usual “goo” associated with e85.You must be...
  • pauleyman replied to the thread CrackedDSM's boring new project (420a).
    · 138 9,280
    I'll comment on this one. I deleted a post of his recently. I sent him a msg even told him I didn't want to do it but I felt the info to be incorrect and I thought a correction would just be unfavorable. I will elaborate to moderators if...
  • chrysler kid replied to the thread 2G Factory keyless entry help.
    · 32 1,641
    I dunno man, it’s the first thing that pops up on eBay when you search for itYou must be registered to see element.
  • diambo4life replied to the thread Drag Race Build Project 98 Eclipse.
    · 127 16,005
    Sick! Looks like a completely different car now! :rocks: :rocks: :rocks: :rocks: :rocks: :rocks: :rocks: :rocks: Still need to find some hanger to properly support the exhaust better under there. I installed a 3" muffler. It's quieter...
  • pauleyman replied to the thread 2G Question! Is this timing or rod knock? And how can i find out.
    · 28 1,373
    You can verify crank mark by manually checking piston position. That will tell you if the crank plate is on right.
    · 23 947
    here is the log. I noticed when I tried to start on just the battery it was acting like it was having a hard time even with 12 volts spinning the motor. I put it on the jump box and it spun but still only stumbles.Hopefully you see something...
  • danl replied to the thread 2G Alternator Plug needed?.
    · 14 976
    I see them now, they are right up to the diode. At first glance I thought you wrapped bare wire around the diode lead and called that good.
  • DiamonDSM98 replied to the thread ECMlink 2G Tuning.
    · 10 767
    I'll get timing adjusted correctly and everything else and I'll come back with another log of it idling for awhile. Thanks !
