zcopp
- 42
- Dec 25, 2025
Arizona
This is the Build Thread for Z's Desert 1GA GSX. Reply below.
If you can find 1gb, yes, direct upgrade. 3kgt/stealth NA model also have 2-piston that work. If you plan to replace the lines too, look into 2g or better yet, Outlander calipers (but mind your wheel size).Is it worth upgrading 1GA calipers to 1GB calipers which can readily be bought? I remember pulling 2 piston calipers from junkyard 3000gt/stealth a very long time ago but the specifics on "what's desirable to swap to on what models" evades me!
Those are NLA with no aftermarket replacement so you have to get creative here, unless you can find a good used set.The cockpit trim (the chrome looking strips along the doors and windows... has anyone "restored" these? What's the best path? They had some kind of nice thick plastic but 35 years in the desert has killed them. Plastidip comes to mind? Is there some kind of thick permanent plastidip?
Best bet IMO would be to rebuild both. Reman racks might be available, but do some research on that topic here and you'll understand.The power steering is a mess on this car. Would it be worth waiting and getting an electric MR2 pump and an upgraded alternator/beefy battery or should I just rebuild the rack and pump? Can new/reman racks and pumps be bought these days? There IS a reman rack but it just says "1990 Eclipse" and doesn't list what trim its for. I'm unaware if the GS/GST/GSX pumps and racks are different in any significant way. Are there any other power steering options that I'm missing? Or is a manual rack worth messing with? I have no frame of reference on a manual rack and if it's basically the same as a depowered power rack.
, but from 10 ft you’d never know, still looks better than 2/3rds of the metal showing
Between my own, friends, or shop cars, I think I "did" a cool 200k worth of parts/services on DSMs in 2003-2004. It's wild. I think I can make something super unique that will turn heads for a reasonable amount... as long as it doesn't break every time I look at it funnyNot a cheap hobby
Thanks! I forgot how painful it is to work on one of these out of a plain garage! So painful getting under this for anything that needs to be done. Thankfully I've got most of the tools and things to gett'er done. It's going to be super rewarding to get it back together cleanly and have it run well. I'm not going for high HP but I'm expecting it to ride and run like a dream!Wow lookin good! Congrats on the progress
I was just reading your build thread and saw your clutch pedal woes in 2022. I also saw the same exact problem with a few other builds I've read up on here. It always kills me to see folks go crazy with shimming the pivot ball (totally worth it!!!), replacing slaves and masters, etc... and it's always that damn pedal!Wow lookin good! Congrats on the progress
, I can relate to the enjoyment of simply cruising it around town.
, i had crazy slop in the z bar from the plastic being obliterated and the hole was oblong so i drilled it out and replaced it with a brass bushing, i also installed the brass bushing at the end of the assembly where you would normally weld it but I didn’t weld it thinking it would be fine, but on my south bend 2700# clutch I couldn’t fully cure the drag, finally hit my wits end and went auto
, I still have my pedal assembly if you’d be interested, it’d be a great rust free candidate for welding
Yeah, I was *really* into these cars around 2002-2005, like was the lead mechanic at an AWD dyno shop kinda stuff. I had a few roomies that also had DSMs. I think in those few years, I either owned or built about 20 of the cars! I remember driving into the Walmart parking lot and easily seeing 5-6 usually non turbo random DSMs. I went into the military around early 2005 and by the time I got out, the DMSs were basically all gone! Now, I'm in a valley in northern Arizona now and I don't think I've seen a single running 1G (maybe 2-3 random waaaay run down 2Gs) in the 5 years I've been here. I'm guessing most people will struggle to even comprehend mine when I start driving it around.Dude you never see these on the road anymore, I can relate to the enjoyment of simply cruising it around town.
IIRC I actually was so pissed off when I figured out the "clutch lift" thing after shimming my pivot ball AND knowing how bad changing the pedals was from the AWD > Manual swap that I just threw some protective matting up in there and went to town on it with the MIG in place. But it sure as heck fixed the clutch engagement issues. When I saw both you and @Anfurnyy with bad engagement problems from years ago, I was basically screaming at the computer screenI actually DIDN’T weld mine..but i should’ve, i had crazy slop in the z bar from the plastic being obliterated and the hole was oblong so i drilled it out and replaced it with a brass bushing, i also installed the brass bushing at the end of the assembly where you would normally weld it but I didn’t weld it thinking it would be fine, but on my south bend 2700# clutch I couldn’t fully cure the drag, finally hit my wits end and went auto
) that I'm taking off of this car. Also, don't tell my girlfriend but I'mma probably start a damn DSM junkyard on my land in the near future at this rate!
Thanks! I'm a little worried that it's like 300-500 HP over what I'm aiming for (~350 wheel target)! I assume it won't be funky to drive with a 20g pushing ~23 or so PSI. I don't think I'll get a big torque hit but we'll see!Nice work! I like your Intake Manifold
