Your most recent welding pics
T3 collector for a motorcycle manifold
T3 for a motorcycle? wtf?
Same stuff, but with a #8 Pyrex cup. Running out of scrap.
1/8" steel, 3/32nd 2% ceriated tungsten, 3/32nd ER70S2 filler, 120 amps, #8 Pyrex cup. Working right to left.
Back side:
There isn't any scaling on the metal right? Try brushing an area clean then welding. Turn the heat way down it looks like your burning it. See how large the heat affected zone is? Try to make it much smaller by kicked the amperage down and possibly moving faster, or maybe even try pulsing manually if you don't have the feature.
Also try a 1/16th filler. I tend to like those better on steel.
1/4" cs 150-160 amps standard collet #8 cup 2% lathenated 3/32s er70s2 filler. First half a small weave second half just dabbing.
Has anybody ever had this happen to them while stick welding?
I was practicing with 7018 rod on 1/4'' steel. I got to the end of the weld, flipped up my hood, and the slag was automatically peeling off the weld. The temperature of the base metal, my travel speed, angle, and arc length were all just right, it was like the stars were aligned LOL
When I was takin my SMAW class it happened a lot.... 7018 is a nice easy rod to run
Yep happens when you did a damn good weld :thumb: i was stoked when this started happening to me at school LOL
practice on some 3/32" stainless plate....
sch40 butt weld...
mike
Got some more scrap. 1/8" steel, 3/32nd 2% ceriated tungsten, 3/32nd ER70S2 filler, 120 amps, #8 Pyrex cup. Working right to left.
Back side of previous weld.
Got some more scrap. 1/8" steel, 3/32nd 2% ceriated tungsten, 3/32nd ER70S2 filler, #8 Pyrex cup. Working right to left. — at House of Big Brown. 105 amps this time.
Went to 115 amps, seemed a lot better here. Pass 3 & 4 from right to left .
Back side from previous pic.
Went to 115 amps, seemed a lot better here. Pass 5, I feel like this is my best one so far, the gap started to get a lot bigger as you can kind of see here.
Back side of previous pic.
Still at 115amps, I had a lot of trouble with this gap, so I tried to "walk the cup"/do a "C" motion to help, I'll need to work more on this.
Full shot of days work (20min?)
I had a weld test at a job and i did an absolute tits root pass and it filled the whole thing. Then the inspector is like, okay do a cover pass and i gave him a wtf look. Did it and burnt it from lack of gas.
Pissed me off LOL the pirge was awesome woth minor minor suck back.
Thought I would share some copper and brass roses I made a few weeks back. I've made hundreds of these from steel, but this is the first time from other materials.
Picked up some more scrap. Not sure what coating is on here but I didn't like it.
I tried #6 cup, 120-125amps I believe, still on the same stuff as before. (No changes to equip rest of the pics)
Penetration on the back side wasn't that good, still having issues starting the weld with this type of joint.
Same as previous, just closer:
Backside of previous pic:
Underside of previous.(This is good right, I mean the penetration)
Got a bit more comfortable, starting it and getting the puddle to move is tough still.
Backside from previous pic:
Underside pic from previous two pics:
Some more junk from work. Gets repetitive sometimes, but at least it only lasts a couple days and then I'm doing something new. It helps that they let me wear headphones :rocks:
These are some kind of slotted lids that get bolted onto a metal box, I think money gets put into the slot. Either that or they're for suggestion boxes that you fill out a slip of paper and drop it in.
Either way, it seems way too over-engineered hahaha
This is my "office":
Here's a jig I helped design:
I have to shear sheets of 16ga. steel and then deburr, bend, weld, and grind it to make the slots:
I used 308L stainless rod for the pictures, but normally I use ER70S2
Here are a few hub to caliper brackets I done last week for the lancia stratos rally cars.
