Your most recent welding pics
Some more pics from the t3 manifold I'm making.
That is unreal, you are very talented aaron.
Approximately how many manifolds did it take for you to perfect your skill ?
Thanks. I think I'm far from perfected it though. Still learning and getting better. I believe I've made 6 or 7 manifolds now.
What about the other two runners?
Started to add one today.
I dont, just some of it in pieces of sch10 nothing complete. I had to buy a vibrant collector cause i dont have a miter saw so it was more expensive i only did one.
That's the only pic I've got of it. I've made a few different ones, I like this one the best. Angle changes depending on collector height, 11-13 degrees generally.
What diameter is the larger pipe? And how is that mounted to the saw?
My bandsaw is small, it's a karma one. I still need to fix the vice on it.
It's welded to that steel plate you can see in the pic. I don't recall off hand the inside diameter of the tube. I have both of harbor freights bandsaw's, they work great once you ditch the blades they come with.
Aaron,
I built my first manifold, which is located in the thread below, it would be wonderful, if you could spare a couple of minutes, to comment/critique some of the things that I have done during the creation of the manifold, since you have a vast knowledge of material science and fabrication. It would be a great oppurtunity for me to learn through your eyes.
Thanks for your consideration in advance.
regards
w
Guys I'm doing a -8 bung on my sending unit, does it matter if the hole is centered with the bung as long as the whole hole is in there?
Reason being i have tight clearance issue.
Well this is my own, i wouldnt think there is a problem if the hole is off ce tered as long as it's inside the bung. I'm keeping the oem connection below
Pic 1 and two denote what I'm talking about. Someone let me knownif thats okay!! And quick! I wanna weld it up!
One down one to go, waiting on input for the big one, small one has some gas pockets so i made sure to autogenously get them out and grind down a bit to be positive. I used a weave
^ thats the good side
Then i had some gas i terferance from the siphon hose here and yeah you can see my fix
    • Sdcryan1
