ed1380
Supporting VIP
- 2,973
- 51
- Sep 29, 2007
ATL,
Georgia
So wheres the turbine outletwaste of a tubular manifold i think...
why waste exhaust gas? It'll cause it to spool slow. Keep it like that
. my roommate moved shops so had to put everything on hold till the new shop is setup. the manifold will be done the next time i go up there. im on a budget. ive spent about 200 bucks so far. that's a better deal than buying just a cast t3 manifold or a crappy ebay t3 and still having to make a downpipe
.Hummm. I got 40 90* and 25 45* for 300 bucks you musta gotten ripped.
i typod.Of course it will work - but in a manifold situation with the heat cycling a weld that does not have full pen or is sugared at all is likely to suffer from cracking. The failure point will just depend on how hard the OP runs his turbo, EGTs etc.
Its very very hard to make a manifold perfect, i might even say it's impossible.... I know i haven't done one yet. Shit, full-race's machine welds don't even fully penetrate....all you can do it try you best, learn from your mistakes and continue bettering yourself from all of it. Some of us are very good, but none of us are machines.
bummer.
the cup just cracked off the tip in a perfect circle leaving the gas lens 100% exposed. Like a 3mm circle cracked off the tip. Guess I'll be def needing one of what you have.
