Your most recent welding pics
What do you use for tabs? And how heavy of springs? These typical Home Depot springs?
1/8" steel loops and the springs are pretty heavy.
mike
Drain for catch can and practice OSCJ.
Patched up a DC sports B series header and swapped head flanges to fit my 4g92 Mivec motor. Welding tube is ugh...hopefully as time passes i can get the pretty dime stack look
The dent! Damned over lowered civic LOL
I used part of a stock Mirage RS header to make the patch, the bend radius was not quite the same but a few taps with a hammer and it lined up enough to net a leak free patch
The outer runners lined up but the inner 2 were off by a few mm. I used a combination of a bench vise and one of those squeeze clamps to get them lined up with the flange.
Pedal was set at ~35amps and i was using anywhere between 1/2 and full pedal at times. Argon was at 20cfh, same 1.5% lanth, #8 cup and gas lens with ER70S-2 filler
Placing an order for some materials to make an intake and extra stuff to mate this header to my super jdm tight discontinued 5zigen exhaust
got most of this k20 header done..... a few more things to go.....
also made some sweet extended top hats for a crx this morning also.....
mike
Those stock mounts are mild steel so did you weld stainless to the mild? 308 or 309?
Why not mild steel?
Is there a difference between 308 and 309? From stainless to stainless and from mild to stainless?
^good to know. Thanks guys!
Mike how did you deal with lining up all the pipes and welding, did they shrink and not want to fit the merge collector?
Just picked up this HUGE gas lens champaign nozzle. I can't wait to test it out tomorrow!!!
The picture does it no justice on how big it really is. That is a standard gas lens 9/20 cup next to it.
Got to play with it tonight for a little bit. Cranked up the gas to around 28-30 just to play around.
My thoughts = ####ING AWESOME!!!!!!
The beads all had NO color at all which is perfect from what I've been told. Then do the next row of dimes next to that one and they will turn gold and purple.
Maybe it's just me, but playing with this large gas lens notice how small the HAZ is. I put the 9 gas lens kit back on and 15cfh and it's a bit larger.
No link sorry. Just called 800-usa-weld and talked to them and got one.
Post flow I changed around, from 11secs up to 20seconds.
What I personally do is when i'm done welding I taper off and just barely keep an arc, to keep the gas flowing. Or if post flow isn't adjustable start the arc again.
i wanted to make a cheap t3 manifold for my 4g63 swapped elantra and came up with this. i had my roommate weld it up. still need to add the wastegate runner and t3 flange. its a mild steel flange with sch 10 304 stainless runners
Whels - pm me all those parts and where you got them. I would love to build one.
Did the flange warp at all?
not that i can tell. the flange was c clamped the the table
