sepulchral
- 61
- 2
- Dec 9, 2005
midlo,
Virginia
Bought a 1995 Eclipse GS-T
- Evolution III Motor w/ T25 Turbo @ 14 PSI
- FMIC, Exhaust, Manual Boost Controller
the for sale link: http://www.dragva.com/forums/showthread.php?t=120564&highlight=1995+evo
I got it from a guy in Dulles, VA drove it back to my hometown in ripley, West virginia. The car had a sputtering problem at first, so i checked the plugs, put them back in and the car burns white smoke like crazy.
I check the oil and there are little bits of non-magnetic metal (brass?) in the oil, and the oil is chocolate milky.
I proceeded to remove the oil pan and beforehand, drained the oil, and the oil looks like a golden chocolate milk color, with microscopic specs of brass floating around.
The guy i bought it from said the engine was just rebuilt, but i signed a paper saying as-is condition, and its been two weeks since i purchased the car.
SO what i need to know is what the brass shavings could have come from, and is the antifreeze in the oil im guessing from a blown headgasket or a cracked sleeve?
I'm NOT experienced with dsm's at all, so please help me with as much info as possible, because frankly, im in the dark.
I'm guessing the shavings are from rod bearings, but what could have caused that?
Here is a list of things i'm thinking i have to replace:
Headgasket
Oil pump
Water Pump
Rod Bearings
Get crank balanced
Where do i get parts for the evo III motor at an affordable price and are there any FAQS out there for replacing this kind of stuff, also i need torque specs for just about everyting, especially for headgasket. Please specify whether specs are in ft-lbs torque or lbs per square inch.
Thank you..
Michael
Headgasket
Oil pump
Water Pump
Rod Bearings
Get crank balanced
Thank you..
Michael
