Just bought car need help!!!
dsmnovice
Dec 13, 2009
north port, Florida
Just bought a 1997 GS-T with a lot of Mods done to it, it runs fine till it gets into boost then, spits, farts , and back fires. Has Turbonetics turbo kit (don't know what turbo, how do I tell) header, big injectors and fuel rail , full 4 inch exhaust. Turbonetics waste gate. Gretty blow off valve. AEM Tru Boost gauge/contoller. Still has what I think is the stock MAF. Apexi Neo a/f controller. from what I have been told my problem is probably the stock MAF not being able to handle all the boost of the big turbo. I need some help with what to do to check this and what I need to add to this setup to make the car run right. The guy I bought it from bought it from someone else and did not all the stuff in the car. He says it is a "built" block and has aftermarket cams in it , but I am not sure about any of that. Any help anyone can give me would be graetly appreciated as I am new to the tuner type cars but do have a lot of mechanical experience. Thanks for your help in addvance.
1.) boost leak test
2.) switch to a 2g maf
welcome to the DSM world, you have to do a lot of reading my friend . reading and reading and reading is the answer now
and then do a boost leak test
can you take some pics of the engine and the ride . we might help you big time
cheers
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
