Wtf
GoAt
Jul 11, 2011
Ferryville, Wisconsin
My 98 eclipse gsx just started heating up and now when i start it up it goes to the half way point on the heat gauge then if i rev it a tiny bit, the needle shoots up gauge... what could be wrong and what should i do?
forst thing I woud do is pop the hood, then remove the rad cap (COLD) then start the car and rev it.. if water/coolent gysers from the rad.. good sign of a blown HG
Really?? I did this after a HG change and thought it was the water pump just pushing the coolant.
IDK, this was 4 months ago. Still holding strong.
Sounds like you should bleed the coolant first. Sounsd like air in the system to me.
Just dealt with this myself. My t-stat was stuck and the radiator cap was expired (the rubber gasket was corroded).
Circled in red is the thermostat housing and the radiator cap you should check. You could also be low on coolant. When you remove the cap, you should be able to see green coolant. If not, you're probably low. If you're full up on coolant and your cap looks all right, then you'll need to drain the radiator via the small plastic plug at the bottom on the driver's side.
You're sensors could be shot or have a loose connection. Does the fan still come on when it gets hot?
97gst spyder...... not an inch or so over the filler neck... I am saying like a foot up in the air, if the HG has let all the compresion in to the cooling system it will shoot wayyyyyy up
Same thing happens, only with oil and sideways out of the car, if you forget to put the oil plug bolt back on the passenger side of the head. LOL
Glad to hear that you got it resolved, Goat. :thumb:
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
