Wrong saturn alternator?
97gstnick
412
Mar 21, 2004
Peoria, Arizona
Don't ask me what year this alternator is from because I don't know. I had some guy pull it from a saturn motor and sell it to me. I inspected it before I bought it and it looks just like the alternator for the swap. The problem I am having is the tensioner arm from my motor being too long for this. I did what the write up says and flipped it upside down but that doesn't help. It is way too long and the lock bolt won't reach into the groove to keep it locked in. I attached some pics so the saturn swap experts can chime in. Thanks again guys.
ps. I removed the black plastic cover if you were wondering.
It should fit when you swing the alternator down and attach the belt. You will have to loosen the bracket and let it swing down also.
Well you can see in the first picture the bracket doesn't come close to alternator adjustment hole. The alternator is rotated as far back as it can go right there. Its actually sitting on the oil filter housing.
