Wrong Headgasket?
MikeL18
43
Sep 27, 2008
St. Louis, Missouri
I picked up a Felpro head gasket from O'Reilly's (pt# 9627PT) and it looked a bit different from my normal one. Looks like the cylinder seals are bigger. Is this normal or did I get a wrong head gasket? The stock one fits perfectly over the block surface.
Here's the old HG:
And the new one. You can see where the old one had a bit of space between the head gasket 'rings' and on the new one they touch.
Your new head gasket was designed to accommodate a larger bore. It will work but I personally prefer a mls hg that is the correct size for a stock bore
I don't want to go the MLS route since I only had the head decked, not the block. Will the larger HG bore be potentially unsafe compared to the correct bore size? I plan on running up to 28 lbs on a Buschur 20G.
I have the standard ARP headstuds / molylube to go with it. I looked up the part number and it's 3.346" which is 84.9mm so I guess it's correct. It's just not very good for "peace of mind" when the old one looks different, haha.
